99 Cadillac SLS
Old Dec 25, 2008 | 12:58 PM
dfb52764's Avatar
Default 99 Cadillac SLS
Ok, had the headgaskets replaced, changed water pump, and belts, all hoses checked, thermostat replaced, and car runs great except for at times, the temperature gauge will shut over to 3/4 for 2-3 minutes, then go back to the 1/2 way mark. Took back to the mechanic, and burped the system again. Drove for 4 days 100 miles a day with no problems. Yesterday driving fine, and all of a sudden, boom, shoots over to hot, says a/c is shut off, engine hot. Immediately pulled over, let cool for 5 minutes restarted, and then it was fine. Let run for over a half hour sitting with it in gear, no problems?
I ran the codes because the service engine light is on, the abs, and traction control, and here are the results:
B1310-Ambient air Temperature Sensor Failure-Current
C1255- EBTCM Internal malfunction-Current
P1645-Evaporative Emission Purge Solenoid Control Circuit_History
Any help or advice on this would be greatly appreciated. Thanks in advance. I even reset the codes, service engine light would go off, then came back on, and now even if I clear codes, still stays on.
Old Dec 25, 2008 | 04:51 PM
Default RE: 99 Cadillac SLS
Is there anything it particular going on when it happens? Northstars are a little scary in regards when head gaskets are replaced there is always a chance it wont work even when 'time-sert'ed. It might be worth having CO test, to be sure engine is still sound.
Old Dec 26, 2008 | 10:36 AM
dfb52764's Avatar
No car is driving fine, just drove it over 100 miles with no problems for overheating?
tyjuti
Oct 15, 2012 04:20 PM
kidcudi
Jun 16, 2009 09:25 AM
mpe331lx
Dec 15, 2007 11:01 AM
jlc608
Apr 30, 2007 08:35 PM
Mugerjr
May 2, 2005 04:22 PM
