68 cad deville starting problem
Old 05-09-2010, 10:26 AM
norwal's Avatar
Default 68 cad deville starting problem
68 cad coupedeville convertible replaced starter/solenoid and regulator..still won't start. Strong battery key on 1 turn it clicks once
Help! Ran great up till this
Norwal
Old 05-09-2010, 07:06 PM
Why have you replaced starter,solenoid, & regulator? What is the condition of battery cables?
Old 05-09-2010, 09:02 PM
norwal's Avatar
Default caddy no start
Brother-in-law said same thing. check out battery cables, jump start to see if it catches. Battery appears to be full of juice. Exactly how do you check battery cables condition except for cleaning? Shall I just replace?
I will do the jump start to see what happens
Old 05-10-2010, 04:54 PM
You can test them with voltmeter. Also visually by lookiing for corrosion on terminals and where they attach engine block or starter. Cadillac also used a braided ground strap from engine to frame. If cable insulation is split and copper cable can corrode turning green or "rust red" color. If you have the "bolt on" terminal repair kit you need a cable. When replacing cables get the correct gage and length.
Old 05-25-2010, 11:44 PM
norwal's Avatar
Neutral safety switch was reason no start 68 caddy.
At least I ended up with a replaces starter and voltage regulator also.
I am happy again
macarose
04-17-2010 07:35 PM
Hank Preusser
01-26-2009 10:11 PM
alix09
06-08-2007 02:42 PM
Kevink
01-14-2007 01:20 PM
theshawfamily
12-27-2006 06:45 PM
Quick Reply: 68 cad deville starting problem
