68 cad deville starting problem
68 cad coupedeville convertible replaced starter/solenoid and regulator..still won't start. Strong battery key on 1 turn it clicks once
Help! Ran great up till this Norwal |
Why have you replaced starter,solenoid, & regulator? What is the condition of battery cables?
caddy no start
Originally Posted by slowroll
(Post 37948)
I will do the jump start to see what happens |
You can test them with voltmeter. Also visually by lookiing for corrosion on terminals and where they attach engine block or starter. Cadillac also used a braided ground strap from engine to frame. If cable insulation is split and copper cable can corrode turning green or "rust red" color. If you have the "bolt on" terminal repair kit you need a cable. When replacing cables get the correct gage and length.
Neutral safety switch was reason no start 68 caddy.
At least I ended up with a replaces starter and voltage regulator also. I am happy again |
