1986 Cadillac Engine Swap
Old 01-30-2015, 07:19 PM
TheReaper's Avatar
Question 1986 Cadillac Engine Swap
Ok, I know from reading other forums that I will receive fire for what I am about to ask. I have a 327 sbc that I want to swap for the 307 that is in it. I would like to know what i may be facing when I do the swap. What am i going to have to do besides the mounting. Any help would be appreciated
Old 02-01-2015, 11:14 PM
Katzmans Caddy's Avatar
The transmission bellhousing is likely going to be a bit of an issue. Generally transmission had BOP Buick Pontiac Olds patterns and Chevy had its own. Have you considered using an Olds 350 or 403 engine?
Old 02-02-2015, 08:25 AM
TheReaper's Avatar
I have thought about it, but i already put the money into the sbc, and with the research that i have done, I'll be working with a dual pattern bell housing
Old 04-08-2015, 10:47 AM
foxxyshazam's Avatar
If its a computer controlled carb, you may have to delete the computer if you're looking to go with a more performance oriented carb. What are your goals for the car? Sounds like a sweet build!
Old 04-08-2015, 01:39 PM
TheReaper's Avatar
It wasn't a compu carb, and it started right up with very little issues. The transmission was no issue as it was a 200-4r, so it fit. the car sounds nice and loud, i have been working on the tranny and now have gotten the full vehicle working.
Old 04-09-2015, 09:35 AM
Glad to hear!! hopefully you get a lot more power from the swap! I know the 307 can be quite anemic, especially in a car over 4,000 lbs!
DECOR97
03-22-2010 09:27 AM
DECOR97
03-19-2010 10:35 PM
DECOR97
03-06-2010 06:24 PM
GrishkaPhil
11-30-2009 08:31 PM
Quick Reply: 1986 Cadillac Engine Swap
