Sponsored by:
Sponsored by:
wont start
Old 09-10-2007, 06:14 PM
tpeder's Avatar
Default wont start
I have a 1980 eldorado. When I try to start it it says starter disabled due to security system. Help please.
Old 09-12-2007, 12:57 PM
Default RE: wont start
I have a 1995 Seville that had the same problem The security system light kept coming on and "wait 3 minutes" and when the "start car" showed...the starter wouldn't even turn over....I found thefix here on the forum...we clipped 2 wires connected to a plug at the base of the steering column that leads to the ignition and soldered the wires of a new resister (make sure correct olms) into the plug....essentially bypassing the resister in the key. Car started right up and security system still works. The new resister cost 2 cents....saving hundreds of dollars. You may still we able to find the posting that we found here. Hope this info helps you or someone else out there.
Old 09-15-2007, 07:29 PM
most likely need an ignition key cylinder
Old 09-15-2007, 08:03 PM
Katzmans Caddy's Avatar
Would trying the spare key start it?
Old 02-10-2009, 01:06 PM
dfbrown21's Avatar
Has anyone ever had problems with security system after using resistor bypass. I have 98 Eldorado and got the remove key and wait 3 minutes message for one day, then the starter disabled message appeared without any wait 3 minutes. Do you think bypassing the resistor in the key will cure my problem?
Old 02-10-2009, 08:14 PM
If you do it right, Vats will be inop. However don't let it get out. Your car could be gone in less than 60 sec.s The quickest I know of is 11 sec.s
Jack West
11-12-2012 11:07 AM
sparky570
08-06-2012 08:55 PM
umoms
03-03-2008 02:04 PM
mikey250z
09-03-2006 08:53 PM
iceberg7181
02-06-2006 02:16 AM
Quick Reply: wont start
