Vin Decoder
or
Login with Facebook
1993 seville ignition coil hot wire burning up
Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Sponsored by:
04-18-2017, 06:37 PM
shawn14120
I start car and ignition coil hot wire burns up...Why??/ its a 4.9
08:32 PM
shawn14120
Find all posts by shawn14120
04-18-2017, 08:18 PM
slowroll
explain better 4.9 or northstar
slowroll
Send a private message to slowroll
Find all posts by slowroll
04-18-2017, 08:32 PM
shawn14120
Thank you..Its a 4.9
shawn14120
04-20-2017, 12:30 PM
slowroll
Ignition coil is in distributor car, so there isn't an actual coil wire.
slowroll
04-21-2017, 11:48 AM
shawn14120
Problem Solved...The last guy changed the coil and cap and forgot the ground strap..it cost 2 dollars
shawn14120
05 Deville Ignition Coil Assembly concern
02and05Devilles
07:27 PM
Engine Coolant Hot/Engine Hot/ messages
Mags1
07:37 PM
2005 escalade 2wd ignition and door keys different - ignition key lost - help!
sj22
08:44 PM
power antenna hot wire??
STSSCOTT
09:17 PM
How HOT is HOT for a northstar engine. When do you suspect blown head gaskets
bighank
07:50 PM
Service Ride Control
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
02:15 PM
