1993 seville ignition coil hot wire burning up
I start car and ignition coil hot wire burns up...Why??/ its a 4.9
explain better 4.9 or northstar
Thank you..Its a 4.9
Ignition coil is in distributor car, so there isn't an actual coil wire.
Problem Solved...The last guy changed the coil and cap and forgot the ground strap..it cost 2 dollars
