2000 seville won't turn over
With no signs of a problem before, my STS seville wouldn't turn over. When you turn the key the cluster panel goes out and there is a definite click on the starter but doesn't engage.The headlights do not go out at any time.I've checked all battery connections and the starter relay in the fuse panel clicks also. I'm just trying everthing before I pull the manifold for nothing. Any ideas? Thanks
RE: 2000 seville won't turn over
mreperf......welcome...... please check out Member Introduction on the site, check things out there............theForum can help you, with no problem.
later......... again welcome!
mre, I'd be checking the starter ground and the solenoid. As long as fuse and relay check out. Jumper the starter with a hot wire to make sure it spins then you will know if it's solenoid for sure.
11-05-2009 09:49 AM
