Problem: Drivers power window malfunction
Old 12-28-2013, 04:57 AM
anash3's Avatar
Default Window issue
The Window motor arrived Christmas eve.
I installed same yesterday morning.
The job was not as bad as I though..
Window seems to work perfectly so far time will tell.
As for the shift know...That will require more research
  #12
Old 01-06-2014, 04:16 AM
anash3's Avatar
Default Window motor issue
Well the window motor fix did not last long.
I had funny smell come from the door area, The window STOPED working.
Though it might be the switch or wiring issue....Not So
The motor had brown oily substance at its base, the smell of burned substance was clear.
I checked wiring to motor from switch...All is well
With motor out of door, I applied 12v power directly to motor....No Action.
New motor was placed on order, and is in the "Pipeline" @ No charge.
To be continued.....
ricks95deville
03-08-2009 06:22 AM
32vnorthstar
02-25-2008 09:01 AM
khanawalt
11-25-2007 10:04 PM
CrusinCaddy83
11-01-2007 06:51 PM
kevinrea
07-10-2006 11:48 PM
Quick Reply: Problem: Drivers power window malfunction
