Another fuel line failure/leaking into engine compartment
Old 06-04-2010, 06:48 PM
justtalkin's Avatar
Default Another fuel line failure/leaking into engine compartment
My 1996 STS has suffered another fuel line leak...plastic fuel line coming up from the subframe to the fuel rail bolted to the engine. This time the leak is right where the transmission cable rubs up against the plastic fuel line. What are the replacement options? A repair kit? Or a complete replacement fuel line?
Edit/Delete Message
Old 06-05-2010, 10:05 AM
It would be a fuel line replacement, the fuel lines aren't designed to be mended or patched. Care has to be taken in regards not to kink new lines when installing.
Old 06-06-2010, 07:55 AM
justtalkin's Avatar
Slowroll, thank you for your reply.
rufrydermg
04-20-2015 03:04 AM
edgrmndz
12-18-2012 04:40 PM
Randy Trets
Automatic Transmissions
02-11-2011 05:38 PM
caddydaddyuk
Aluminum Block V8s
15
07-30-2009 09:03 AM
caddy55
Vintage & Classic Cadillacs
04-05-2008 02:29 PM
Quick Reply: Another fuel line failure/leaking into engine compartment
