2000 STS motor mount, coil pack, leakage
Old 06-27-2007, 11:26 PM
brandonjohnson's Avatar
Default 2000 STS motor mount, coil pack, leakage
I recently had my plugs replaced and air filter. However, my mechanic told me that I need a motor mount and a coil pack. Does anyone know what either one of these items and are they important to replace. Also, when it rains water seems to go through my trunk and through the mats and piles up where the spare tre is. Please I really could use some help.
Old 06-28-2007, 04:59 AM
FLCaddytech's Avatar
Default RE: 2000 STS motor mount, coil pack, leakage
The coil pack going bad would either make the car run poorly or set a check engine light.
Now the motor mount is a common problem and can lead to other issues if not repaired.
Old 07-05-2007, 11:12 PM
Katzmans Caddy's Avatar
For the water leak have you checked your weatherstripping around the trunk?
steppup37
12-16-2010 03:35 PM
silverlx
03-13-2007 10:35 PM
Eddiek
11-01-2006 08:54 PM
jxsmit
06-29-2006 10:13 PM
Quick Reply: 2000 STS motor mount, coil pack, leakage
