98 Eldorado ETC: ABS, Traction, and Serv. stability system. Help!
Old 06-12-2008, 09:31 PM
vamike23's Avatar
Default 98 Eldorado ETC: ABS, Traction, and Serv. stability system. Help!
I have a 98 Eldorado ETC. I have a traction control light on, ABS light on, and service stability system. I pulled the codes and this is what I got as the current ones:
PCM P0300
PCM P1380
ACM B1347
TCS C1235
Please, if you could tell me whats wrong I'd greatly appreciate it. Thanks
Old 06-30-2008, 12:03 PM
Default RE: 98 Eldorado ETC: ABS, Traction, and Serv. stability system. Help!
Not sure I can help much, but I can give you the code meanings. One of the marvelous Tech's will be around shortly.
PCM P0300 - Engine Misfire Detected
PCM P1380 - Misfire Detected - Rough Road Data Not Available
ACM B1347 - Very Low A/C Refrigerant Warning
TCS C1235 - Right Rear Wheel Speed Circuit Open or Shorted
simmy
03-07-2011 01:43 PM
99STSGUY
Aluminum Block V8s
07-07-2010 06:52 PM
CurleyBill
08-13-2009 02:24 PM
matter
02-25-2009 10:04 PM
Quick Reply: 98 Eldorado ETC: ABS, Traction, and Serv. stability system. Help!
