1991 El Dorado Touring Door Panel Removal
Old 09-01-2008, 10:16 PM
rudedude_2k's Avatar
Default 1991 El Dorado Touring Door Panel Removal
Anyone know how to remove the door panels from a 1991 El Dorado Touring Coupe. I am replacing the speakers and I can't find a good step by step procedure anywhere.
Thanks in advance
Mike
Old 09-01-2008, 10:19 PM
Default RE: 1991 El Dorado Touring Door Panel Removal
ORIGINAL: rudedude_2k
Thanks in advance
Mike
two ways ..
get hold of a FSM
or
go to our Allante FAQ and find the thread where the outfit that provides pictorials to remove door panels is identified.
Old 09-04-2008, 09:27 PM
SS427's Avatar
This is actually a pretty easy removal with the right tools. You will need a door panel removal tool, these usually come in a 3 piece kit with different shaped tools. You will need this to pop the plastic fasteners out of the door skeleton, but make sure you grab the head of the fastener and not just the panel. This will rip the fastener out of the panel. There are some screws to be taken out as well. They are located under the pull handle, one on each side. You will also have to disconnect the wiring from the switches on the back side. I did this from behind after prying the panel up from the door so I didn't have to mess with prying out all the electricals.
Are you replacing the speakers with stock or aftermarket? Also, do you have any pictures of your car?
Like stealth said, the FSM is the best place to look for this info, and that is what I use when I tear my cars apart. I have also found the GM parts book to be very helpful as there are some great illustrations.
Old 09-11-2008, 04:32 PM
I have a similar question; I want to buy a whole new door panel. Does anyone know where I can find one (and NOT a cheap plastic cover)? I have a crack in mine.
Old 09-19-2008, 04:51 PM
SS427's Avatar
You might be able to still get that from GM, but who knows, some specific colors may be long discontinued. I think your best bet is a junkyard car with low miles/clean interior.
Steve
cmlaws
12-28-2011 12:34 PM
Cadillac_Lvr
09-24-2010 06:33 PM
danman7
05-17-2008 10:02 PM
bmw1023i
10-13-2006 08:22 PM
Quick Reply: 1991 El Dorado Touring Door Panel Removal
