"Service Stability Sys"
Old 06-08-2010, 08:11 PM
EDWEG's Avatar
Default "Service Stability Sys"
2004 DTS w/over 100K miles, recent plug change, on long road trip started popping up with "Service Stability Sys" while driving. No other symptoms. Can remove by touching Info button on right of DIC; but, will periodically re-appear. I re-set, then will come back later. I cleared all codes, took a ride, and re-looked at codes, which were ABS C1287 and IPC U1016, both History, no current codes. Reason for SSS? A must fix? Can I take 7K trip w/o worry?
Old 06-08-2010, 08:49 PM
Don't drive over 90 mph, should be OK, fixing the c1287 would be a good idea.
Old 06-08-2010, 09:13 PM
EDWEG's Avatar
TKS; but, what is the ABS C1287 code for? It was HISTORY, indicating a fixed issue. Could it have been pointing to the fronts, which were replaced @ 88k (now 103k) w/rotors turned, etc. Rears were hardly worn.
Old 06-09-2010, 11:27 AM
2001_Seville_SLS's Avatar
Default C1287
There is something wrong with the signal from the steering wheel position sensors. It could be a bad sensor, a bad circuit, or even a bad EBCM. Turning the steering wheel super fast will also set the code.
Clear the codes and see if the problem shows up again. If it does, check the connectors for corrosion.
Old 07-10-2010, 11:03 PM
EDWEG's Avatar
Default Service Stability System
This may be a stretch; but, when the mechanic changed all eight plugs, is it possible he buggered the steering column sensors for the stability system?
Old 08-12-2010, 11:58 AM
gmtechs's Avatar
he should of changed the steering sensor at bottom of column
wear out
qboy7
07-25-2011 09:07 PM
bsstyle2011
03-22-2011 04:07 PM
cadijac
03-28-2008 07:52 AM
08-27-2007 01:22 PM
Quick Reply: "Service Stability Sys"
