2005 DTS Fan Blower issue
Old 11-01-2014, 09:01 PM
2005DTS's Avatar
Default 2005 DTS Fan Blower issue
Hi all, I've been researching but can't seems to find a solution to this problem. So I've decided to put here.
Using the front climate control unit, whether for A/C or Heat, I turn the fan/Blower on, and nothing happens, the fan doesn't blow.
Using the rear passenger climate control unit, I turn on the fan/blower and the fan comes on and blows only out of the rear unit. Still nothing from the front vents at all.
November in Connecticut it's dropping fast and I need heat, and help!
Thoughts??
Old 11-02-2014, 03:01 PM
2005DTS's Avatar
Pulled vehicle codes and got the following...
B3832 - Window related. All windows work except the driverside rear.
B0429 - ??
B0100 - I need a new front impact sensor.
Old 11-03-2014, 02:47 PM
2005DTS's Avatar
Default Fixed
Turned out to be the blower motor was clogged with black powder (carbon/magnet) and causing the blower motor to no spin. Took it out, and took it apart, used sandpaper to clean up the contacts and magnets. Cleaned up all powder and reinstalled, works on command now. Thank you!
kleankicks
06-26-2010 06:59 AM
KathyMartin
11-09-2008 01:35 PM
blondie
08-19-2007 05:57 PM
barbaranna
06-06-2007 11:02 PM
barbaranna
05-23-2007 10:11 PM
Quick Reply: 2005 DTS Fan Blower issue
