Theft System Problem, car may not restart
Old 05-03-2011, 07:23 PM
Tony Lake's Avatar
Default Theft System Problem, car may not restart
Car worked fine yesterday, when I went to start this morning, received "Theft System Problem, car may not restart". Is there a way to bypass the theft system? Any help would be appreciated.
Old 11-14-2015, 12:48 AM
cuzbro's Avatar
Default Its probably your TDM
Check on youtube.com There are several ways to bypass it. My 99 is doing the same thing, except now it wont crank. Ended up costing me just over $600 to get it fixed.
Old 01-29-2016, 11:53 PM
chirogal1's Avatar
$900? To do what? I am having the same problem with my '98. When I got home I parked it on the street in case it needs to be towed (easy access), but it seemed to restart fine. I have seen in other forums that the problem is almost always the wires at the end of the ignition cylinder. Would running a computer diagnostic reveal any helpful codes? If the cylinder wires is the case on mine what can I realistically expect to spend for repair at a non-dealership? Thank you.
Old 02-28-2016, 03:10 PM
cuzbro's Avatar
That's probably the problem you have, that's what was wrong with mine. Youll probably have to take it to a dealer? I couldn't find independent mechanics who wanted to fool with replacing the switch because of the airbag. According to the videos the cost is somewhere between $500 and $900 bucks, depending on your area. Cost me $600 thereabouts.
Old 03-14-2017, 05:11 AM
kd123's Avatar
Default bad cylinder
It's time consuming and a little nerve racking, but I disabled the air bag and pulled the steering wheel to replace the multifunction switch.It's the turn signal, wipers, cruse, etc. if not familiar with the term I wasn't. Youtube had all necessary info. I also misplaced my keys.Called dealership to purchase a key, they informed me that the odds of getting the correct key were slim because cadillac has had issues with cylinders going bad. If you need help with the airbag I will walk you through the process
JBeam4ME
06-17-2023 04:07 AM
wkeithk
08-22-2011 10:18 PM
tommy36079
06-29-2011 06:08 PM
spielberg911
06-29-2011 06:05 PM
jpchris
03-09-2007 11:31 PM
Quick Reply: Theft System Problem, car may not restart
