US Emissions Have a question about getting your car to pass a state emissions test? Ask here.
P0160. Not receiving signal at ecm
Old Jan 12, 2020 | 08:24 AM
Nathan Wertz's Avatar
Default P0160. Not receiving signal at ecm
I have a 2007 srx with a 3.6. A p0160 popped up so I replaced the O2 sensor. This did not fix the problem. While viewing the pid with a scanner it remains a stable .455. I ohmed out all of the wiring and it seems good. I ended up putting the 2 signal wires right at the plug for the ecm and connecting an O2 sensor while hitting it with a torch. Still no change. I did the same test with b1s2 and I can see the signal coming across. After soldering the connections back together and driving I see an occasional change to maybe .5 but mostly it stays at or around .455. I feel like I have a bad ecm input but would like anyone else's opinion before I spend the money to replace it. Thank you in advance.
bennett1240
Oct 9, 2019 12:16 PM
milo
Sep 30, 2011 12:48 PM
rjs12182
Feb 10, 2008 06:02 PM
crdude
Jul 30, 2007 10:29 AM
Stardog
Nov 12, 2006 04:31 PM
