1994 ECM PCM INSTALL??
Old Jan 25, 2008 | 06:33 PM
rjs12182's Avatar
Default 1994 ECM PCM INSTALL??
So I put a new ecm in my 94 sts and now the trans shifts hard. I put the stock ecm in the car and it shifts great. I put the PROM back in the new ecm and it shifts hard. anyone had this?
thanks
Old Jan 25, 2008 | 06:47 PM
Default RE: 1994 ECM PCM INSTALL??
Why are you replacing ecm? Transmission is controlled by ecm. Possibly bad or incorrect ecm.
Old Jan 25, 2008 | 07:31 PM
rjs12182's Avatar
The ECM is a GM reman ECM. I replaced it due to an injecter not fireing. Now the motor runs good (with the new ECM) but the trans shifts hard. I put the stock ECM in and #6 injecter will not fire but the trans shifts great
thanks
Old Jan 25, 2008 | 07:52 PM
Still maybe bad ecm, after all they are rebuilt. Fuel injector driver will not be in the same part of ecm as trans controls.
Old Jan 26, 2008 | 05:24 AM
rjs12182's Avatar
I was thinking the PROM was not holding the trans shift values.
Old Jan 26, 2008 | 06:50 AM
Prom won't lose calibration from ecm to ecm it is permently burn't in. GM prom's program can not be over written., It's not an E-prom which can be.
Old Jan 26, 2008 | 05:38 PM
rjs12182's Avatar
so you think it is a bad reman ECM?
Old Jan 26, 2008 | 07:11 PM
ORIGINAL: rjs12182
ORIGINAL: slowroll
Old Feb 9, 2008 | 04:46 PM
l306x's Avatar
I got a 2ed ECM from the junkyard they did an interchange and it is out of a 95 olds aurora. I put my prom in it from the stock ecm started the car. The car ran but has "no pcm data" I checked the prom it was in good.
So my stock ecm will not fire injector #6 but everthing else works
The gm reman ecm will fire injector #6 and the car runs great but the trans shifts very hard
The interchange ecm (95 aurora) the car just runs in defalt mode and has "no pcm data"
any idea's?
Old Feb 10, 2008 | 09:09 AM
Was reman ecm new or junkyard also? Do numbers on replacement ecms match original ecm?
