lock into a gear
Old Jan 24, 2008 | 11:55 PM
iceracer45's Avatar
Default lock into a gear
how do i get my trans to lock and stay in to a gear,don't want to spend hundreds for a contoller,am looking a the wiring to get at the shift controllers now. has a fresh trans and i dont want to wreck. any ideas or instrution will help post here or call 262 384 1166 chris
Old Jan 25, 2008 | 09:53 PM
iceracer45's Avatar
Default RE: lock into a gear
nobody know,or nobody talking
Old Jan 26, 2008 | 02:19 PM
Is this for a race car or street car? For ice racer in 1st 2 posts does it use stock floor shifter?
Old Jan 26, 2008 | 03:01 PM
iceracer45's Avatar
uses the colum shifter. yes it is a race car so to speak,would like to hold first gear and not shift out would be a lot easierand faster,theres some pics in the street strip column . use this to ice race in the winter for some thing to do.
Old Jan 26, 2008 | 03:50 PM
There is metal piece in column that shifter handle interlocks with that could modified to do what want. It will require column to be removed and disassembled to get to it. Then make detent to hold shifter in low. Bungee cords can also do the job.
Old Jan 26, 2008 | 07:25 PM
iceracer45's Avatar
i want it to stay in first gear in the trans ,not the column, like a shift controller or 12 volt to the shift selonoid,wondering if any body has tried this.
Old Jan 26, 2008 | 08:12 PM
Only way to try to lock it in 1st I know. You can unplug trans and lock it in second gear, default is second only.
Old Feb 13, 2008 | 09:00 PM
iceracer45's Avatar
no body out there ever manual a 4t80 with the selenoids or anything? some body must have some ideas? thanks chris
Old Feb 14, 2008 | 07:08 PM
Shift lever on trans needs to go and stay in L position for trans to go into low. Floor shifter can modified to keep lever in low, stock or aftermarket. A good tran guy can modify trans internally not upshift.
jbann72
Mar 24, 2016 10:24 PM
Joelism
Jul 13, 2009 11:02 AM
Macko11586
Jun 16, 2009 10:40 AM
shrekmobile
Aug 2, 2008 02:56 PM
mr cig
Oct 25, 2006 09:36 PM
