View Poll Results: A poll
50,000 miles - overhauled
6.90%
75,000 miles - overhauled
10.34%
100,000 miles - overhauled
10.34%
150,000 miles - overhauled
3.45%
200,000 miles - overhauled
6.90%
175,000 miles - still going
17.24%
200,000 miles - still going
24.14%
300,000 miles - still going
3.45%
Cost to overhaul $1,500 to $2,500
6.90%
Cost to overhaul $2,501 to $5,000+
10.34%
Voters: 29. You may not vote on this poll
Cadillac automatic transmission life
Old Oct 5, 2007 | 04:19 PM
Default Cadillac automatic transmission life
Meaning, how many miles did your Cadillac transmissions go before it wore or broke?
A minor repair, count it as still going.
Reset your count at zero with an overhaul, but not with a minor repair such as a solenoid R&R.
Old Sep 1, 2009 | 07:53 AM
jons95sls's Avatar
how many miles will they go?an why did they create such a crappy trans for what you pay for these cars.
Old Sep 1, 2009 | 03:20 PM
92_Daddylac's Avatar
im at 93k and still going but thats not to say something could go wrong. I just recently changed fluid and used some lucas which will help the trany live a better life. (I almost sound like the infomercial with that old man) LOL. anyways did you have problems with you.
Old Sep 2, 2009 | 07:31 AM
jons95sls's Avatar
Question 211.989 miles
yep i got a sls and mine has 211,989 miles on the car,1 owner.i got a slite prob with the trans,it was rebuilt about a year an half ago,shifts weird,they say its a sol,in trans but not sure i posted a question,but no reply yet.
Old Sep 2, 2009 | 06:17 PM
I lost the shift solenoids at 127k, pretty minor repair - 94 ETC
Old Oct 8, 2009 | 01:34 PM
joshr45's Avatar
ive lost 2 1991 4T60E's around 120-138k miles im in the process of pulling the working car's transmission and having it rebuilt, the working car's transmission wouldnt have went except it had a cooler leak, the lines rusted through and broke off while i was driving so the transmission burned up, my other car's transmission still "works" technically you just have to shift it manually into first to get it to move
Old Nov 9, 2009 | 11:06 AM
STSevilleSTS's Avatar
95 seville sts has 160,000 miles on it now. I am the 2nd owner not sure if the transmission has ever been serviced but the last owner took very good care of the vehicle. I have been thinking of pulling pan changing the filters and replacing only the fluid that came out but Im kind of afraid that may cause a problem. I think I will post a thread on that.
Old Nov 9, 2009 | 11:12 AM
Originally Posted by STSevilleSTS
95 seville sts has 160,000 miles on it now. I am the 2nd owner not sure if the transmission has ever been serviced but the last owner took very good care of the vehicle. I have been thinking of pulling pan changing the filters and replacing only the fluid that came out but I'm kind of afraid that may cause a problem. I think I will post a thread on that.
that should not be a problem .. but do not flush it, or all bets are off.
i be adding a bottle of LUCAS when you refill.
Old Nov 9, 2009 | 11:34 AM
Ok thanks for reply. So pump out some fluid before adding the Lucas so not to overfill, add the Lucas and drive around for a week then drain, change filter, fluid and add another bottle of Lucas? I have seen the question asked before but no answer--About how many quarts total will come out when taking the pan off and the drain plug inside?
Old Nov 9, 2009 | 12:17 PM
yes, i would and do all that.
as to how much fluid you need? well, when i do it i make sure i got a full case by my side and i have never needed more than that .. I say from 6 to 10 quarts?
