1955 Rocker arms
Old May 30, 2019 | 03:57 AM
Kanne's Avatar
Question 1955 Rocker arms
Hi all.
I am doing a total rebuild on my 1955 331 cui engine.
During that work I saw, that there were some shims placed under the rocker arm assembly.
They do not look like something original, and I wondered if they have to be installed again, when mounting the rocker arm assembly to the cylinder heads.
What are they good for?
I can only see, that they are making the distance between the valve lifter and the rocker arm longer?
Could that longer distance cause problems with the valve lifters (they are all new by the way).
If I remove these shims, could that result in a too short distance between the valve lifter and the rocker arm, and how do I check, that I have the correct distance?
I hope my English writing is understandable, and that someone can tell me what to do.
Looking forward to some assistance.
Best regards
Per Kanne
Denmark
eldoradotramp
Apr 5, 2010 06:33 PM
bobfeder
Small Block V8s
Sep 2, 2009 05:57 PM
obosse
Mar 31, 2009 08:49 PM
84CONV
Aluminum Block V8s
May 16, 2007 04:19 PM
pkared
Aluminum Block V8s
May 8, 2007 01:38 AM
