Other Cadillac Models Dont see your model listed above, this is your section!
99 Catera. Low oil pressure starts to overheat.
Old 03-15-2017, 12:46 AM
Brandon BooBoo White's Avatar
Default 99 Catera. Low oil pressure starts to overheat.
Picked up this car for only $500 from my great aunt and today it decides to lose oil pressure and start to overheat and stalls. At 49K this shouldn't be happening! What's going on here?!
Old 03-15-2017, 01:23 PM
It's a 99 anything can happen. Checking fluid levels is where to start? Are the oil and coolant levels full? If not can you see where fluid is leaking? Not that this is the cause but was timing belt recall done and coolant should have been changed at least once.
hccaddie1
10-10-2007 09:59 AM
church_work@att.net
11-08-2006 09:07 PM
2007escaladeEXT
Cadillac EXT
09-26-2006 11:30 PM
Jellobiafra
07-05-2006 11:41 PM
sandawgcaddy
12-02-2004 08:39 PM
Quick Reply: 99 Catera. Low oil pressure starts to overheat.
