skimming DEBIT CARDS
Old Jan 16, 2010 | 11:36 AM
Default skimming DEBIT CARDS
by Consumer Reports
skimming -
thieves set up equipment that captures magnetic stripe and keypad information when you input your PIN at ATM machines, gas pumps, restaurants, or retailers.
Here's how you can protect yourself:
Don't Type in Your Pin at the Pump
Be especially vigilant at gas stations. Gas pumps are notorious for skimming because they're produced by only a couple of different manufacturers, and if someone gets the key to one from an employee, they can insert a skimming device inside the pump where it can't be seen. Best to use a credit card rather than a debit card when you fill your tank.
If you must use a debit card at the gas pump, choose the screen prompt that identifies it as a credit card so that you do not have to type in your PIN. It will still work and the purchase amount will still be deducted from your bank account, but it will be processed through a credit-card network, which will give you greater protection from liability if fraud does occur. This is because card issuers typically have "zero liability" policies for both debit and credit cards, but sometimes exclude PIN-based transactions from that protection.
Stick With ATMs Located at Banks
To reduce your risk at ATMs, use machines at banks rather than in convenience stores, airports, or any isolated locations, advises Darrin Blackford, a spokesman for the U.S. Secret Service, which investigates financial crimes involving interstate commerce. "A thief has to be able to attach and retrieve a skimming device to use the data it's gathered," he says. "And that's more likely to happen in nonbank settings where there's less traffic and no surveillance cameras."
That doesn't mean that bank ATMs are immune, however. In August 2008, Wachovia Bank reported that several debit-card "identities" were stolen when a skimming device was placed on an ATM at a branch in Cape Coral, Fla.
"It's often hard to spot skimmers," Blackford says. "But if you notice a change at an ATM you use routinely, such as a color difference in the card reader or a gap where something appears to be glued onto the slot where you insert your card, that's a warning sign you'd want to report to the bank that owns the machine."
Big5DoubleZero
Aug 28, 2007 09:18 PM
Apr 9, 2007 05:42 PM
