Regular tempature?
Old Dec 13, 2004 | 10:03 AM
elgordo08's Avatar
Default Regular tempature?
What is the regular temperature a 96 deville should run at, because mines runs at around 200 to 210? is that normal? and if not what do i do? As well as the regular Voltage reading? mines is always at around 11.8 when stoped and goes up to 13.3.
Old Dec 16, 2004 | 06:00 PM
tonythemongoose's Avatar
Default RE: Regular tempature?
My 03 SLS runs at 180 to 200 degrees on older cars your tempature would be determined by the type of thermostat you had whether it was a 160 0r 180 degree thermostat and as for your volts you might check all leads to your altenator and check all the terminals connections to your battery due to the fact a drop in volts can be very similar pertaining to your altenator and battery
Old Dec 17, 2004 | 05:12 PM
elgordo08's Avatar
OK thank you, i will check that
SPreston2001
Sep 28, 2008 10:33 AM
house1000sleeved
Jun 25, 2006 01:33 PM
