new sts , with electrical problems
Old Dec 25, 2010 | 01:45 AM
dibbsdesighns's Avatar
Default new sts , with electrical problems
Just bought 99 sts , experiencing electrical issues , need help finding grounding points ,so I can eliminate that part of my troubleshooting process . Already replaced icm . Please help !!!
Old Dec 25, 2010 | 09:30 PM
are electrical problems interior, dash, fuel gauge, back-lites going dim...ETC.. ??? you need to give us more information. what are the miles on the car?
haha lucky its a slow day... i dp have all ground locations on ur car and will send along. read one of my posts E-GHOSTS.. it might help you.
also, i see this being your first post... MMMM have you been in member introduction yet??? anyway.... welcome to the fourm....
Old Dec 26, 2010 | 08:34 AM
Default yes
Yes you're right, the dash goes blank when I try to start, sometimes it flickers in and out. The car will finally start when the check engine light comes on, the car will chime three times and then it will start , there are about 150,000 miles in the car. I have observed moisture I'm the trunk. When I finally get it started , it runs fine . Occasionally it will cut off without warning and I have to go through the same process again , repeatedly turning the key until it fires up . I have read your posts on e ghosts and it was very helpful. But to be honest , when it comes to electronics in a car I'm an idiot. So please bear with me , in serious need of help , cause this is my only form of transportation. Thank you I'm advance , cause I can already tell you're the man I need to consult about this problem
Old Dec 26, 2010 | 04:11 PM
okay so..... let me see if i understand. you can turn the key to start the car, and nothing happens?? if so, when the engine does turn, does it hesitant, or is it slow to turn?
now, moisture in the trunk.... where is it?? a big concern of mine would be
moisture under rear seat where battery and interior fuse boxs/relays are.
now, when it is started and running.....are all electrics work properly?? very important..!!
okay.... so the dash blinking on and off at start is normal, so no concern there.
..... if in fact you turn the key and it doesnt turn over at times, it could be the starter,
starting to go bad..
hope this helps, and keep us posted
Old Dec 26, 2010 | 11:47 PM
Default so frustrated
The engine will turn over every time I turn the key , so I'm sure the starter is fine. Moisture is only in the trunk , none under back seat. When the engine is running , electronics work fine except the drivers door and seat. Which is expected cause I am getting a code for the ddm and msm.
a3zrider
Dec 19, 2008 02:11 AM
99sts
Oct 18, 2007 08:36 PM
delcus
Jul 18, 2007 02:54 AM
Cadillac Allante FAQ
Mar 25, 2007 02:33 AM
ORNURSE
May 6, 2006 02:03 AM
