new here and need help really bad!!!
Old Dec 2, 2009 | 12:16 AM
linus73's Avatar
Angry new here and need help really bad!!!
i have a 96 eldorado and i changed the head unit. ran all new wires to the bose speakers and connected the new radio. the only problem is that i had someone do it for me and he tried to use a red wire from the climate controll mod below the radio as an ignition for the aftermarket radio.. well now my speedometer does not work and i no longer have the information center working. 2 fuses were blown, 1 bieng the cluster and the other i forgot. i replaced the fuses and still no information center or working gauges. so i put everything back to factory and tried disconnecting battery for half hour and still no results. could it be a blown bcm or pcm? and if so whre is the pcm located? i know where the bcm is, but not the pcm. by the way every fuse is good behind the rear seat and under the hood and the factory radio is working, just no information center or lights on climate controll and no working gauges. please help me im lost!!!
Old Dec 2, 2009 | 07:13 PM
Codes? Do you have service manual? PCM is under / within lower air filter housing. It is unlikelyto be the cause.
02pearlSTS
Mar 31, 2023 09:30 PM
mitalismith
Apr 10, 2015 02:23 AM
01SLS
May 26, 2014 10:16 AM
astrodan13
Aluminum Block V8s
Jun 14, 2011 12:24 AM
Mar 3, 2008 10:14 PM
