Hi. Newbie from Castleton, NY
Hi all. I'm new to the group. My name is John and I have a 1983 Eldo. Nice to meet everyone. It's been "enhanced" a bit.
One thing I'm still working on is a trans pan leak. It may be a "warped" pan from over-torqued bolts in the past. Me and a buddy tried to ensure a good seal, but I'm still leaking. Any advice? Any new pans out there? Or, goodness forbid, could my lower end be warped causing a bad seal!
John
Thanks for getting back to me and the advice. Not sure what ring you would be talking about. It leaks with the pan on (and a new gasket) and the spotting is under the pan. Is there something outside the trans that could be dripping? Thanks, john
Would help if you posted a picture of the pan area. You did not mention if you replaced the gasket, if so, what gasket you use, was it cork, neoprene, or the better one which is reusable....In any event the pan should always be flatteded out at the bolt flanges every time you remove it to prevent torque distortion that you mention... Before removing the pan search out the replacement fluid...as the proper & correct fluids are becoming difficult to find these days.....
