found a caddy i might buy
VIN is wrong
engine code 9 (northstar 300hp)
Front motor mount is a little tricky to change. I you are a "handy fellow" you may do it, but the subframe needs to be lowered quite a bit. Good luck with the eldo.
VIN 1G6EL1296PU620954
Year/Make/Model: 1993 CADILLAC ELDORADO TOURING COUPE
Body Style: COUPE
Engine Type: 4.6L V8 TPI DOHC 32V
Manufactured In: UNITED STATES
Search Results: 18 records found in our database
whats wrong with it? the vin ??!?
what do i expect to pay the local shop for the job? under 100 bucks?
Body Style: COUPE
The VIN comes up invalid for some reason.
$100 bucks labor, maybe for one mount.
Depends on the rate you shop charges.
We get 2hrs labor for the job.
93 was an oddball year for the northstar. It usually cost more to repair 'cause the parts were low production.
everthing got better 95 +
But i thing the early ones had the most zip. Fun to drive.
thepoint
Oct 23, 2008 02:15 PM
