Digital Readings
Greetings I'm a new member and look forward exchanging info with you. I have a 1989 Fleetwood and the Climate Control is not working. The trouble started a couple days ago when I turned the ignition switch on and the blower fan came on full blast and would not go off. I had to unplug the hot wire under the hood to cut it off. Then the letter "d" appeared on the read out screen for a minute or two. Then the letter "c" appeared and has not gone away. I have no control of the climate control functions. Some one told me the "c" indicates loss of communication of either the ECM or BCM. That doesn't tell a shade tree like me anything. Does anyone know what needs to be replaced to fix it.Thanks for any assistance. Cary
See if you can get codes. c means clock and d means data. Problem usually centers around fuel data panel, a/c control head, or bcm. A factory service manual would be very helpfull.
http://www.cadillacextendedwarranty.comWelcome to the Cadillac Forum!!!
_____________________________
Cadillac Extended Warranty - Are you covered?
Are your other GM vehicles covered with a General Motors Protection Plan (GMPP)?
ORIGINAL: 158cary
Concerning the extended warranty, 1989 Fleetwood are you kidding?
nickhess
Oct 12, 2010 05:49 PM
