2002 cadilliac deville code p0410
Old May 4, 2011 | 10:25 AM
ADEC's Avatar
Default 2002 cadilliac deville code p0410
I have a 2002 cadilliac deville with a check engine light problem. I had it checked and the ODB code was P0410 . The fuse for the secondary air pump was blown which indicated a bad or sezied pump. I had the secondary air pump replaced and drove the car 160 miles. I assumed after driving 160 miles that the pump resolved the issue. The car sat overnight when I started the car in the morning my check engine came on again. I checked the ODB codes and again received a P0410 indicating a secondary pump issue. Anyone out have the ame problem or solution before I start pumping more money into this issue. Thanks
Old May 11, 2011 | 04:24 PM
88Diesels's Avatar
Check your wiring, the fuse blew for a reason maybe other than a bad pump. I'm getting that code on my O3. It just started
Old May 11, 2011 | 06:54 PM
you may also want to test the pump ...
2002deville2002
Jun 5, 2012 01:49 PM
MrsLLL529
Oct 24, 2009 07:42 PM
mr.jwbrown
Nov 27, 2008 02:43 PM
OBrien
Jul 26, 2007 07:23 AM
planedoctor
Mar 29, 2006 12:37 PM
