Home Projects Got something special planned for around the home? This is your place.
the URINAL BathRm remodel project
Old Oct 10, 2007 | 08:57 AM
  #11
jim's Avatar
jim
Default RE: the URINAL BathRm remodel project
Old Oct 10, 2007 | 09:34 AM
  #12
this one was a difficult decission ..
stiletto thread or BR remodel ... ?
[IMG]local://upfiles/2893/6B109BDB1B1848C687916E00878E3215.jpg[/IMG]
[IMG]local://upfiles/2893/43BB12C5CEB741EA82D02E2FB9AAE7F5.jpg[/IMG]
Old May 19, 2008 | 11:21 PM
  #13
"Why, a man can't walk down Broadway without gettin' urine alls over his trouser cuffs," Jeb Reglard said,
"it's sad and alarming. Shadowfax, been on tippytoes since we left New Jesey, an' he ain't even got toes." soon had the answer, "Why," he said, "It's plain as day. What this here town needs is nothin' but steam urinals!"
[IMG]local://upfiles/3799/F99A32F0A3DF4A81BB8955ED953511F9.jpg[/IMG]
now, for some art ...
[IMG]local://upfiles/3799/8828A39BB39C413680F71D11DD85D6AA.jpg[/IMG]
[IMG]local://upfiles/3799/3AC8CD9FC5C64DE69F9A10EFC02F61D6.jpg[/IMG]
Old May 19, 2008 | 11:23 PM
  #14
more art ...
[IMG]local://upfiles/3799/32D6D734CA554FF58F9916BE55CC9C36.jpg[/IMG]
[IMG]local://upfiles/3799/BECE56AE6E2C4F7BAE0B4D5DADB9A76A.jpg[/IMG]
[IMG]local://upfiles/3799/B25397F1FF3D4508B338EC5951AD5F51.jpg[/IMG]
[IMG]local://upfiles/3799/116F6CE7506748E8A6934DF8F8445682.jpg[/IMG]
[IMG]local://upfiles/3799/E115E829973E4EEFAAB29EA51FAA9C22.jpg[/IMG]
Old Jul 30, 2008 | 12:54 AM
  #15
marthyj's Avatar
asx
Old Nov 14, 2011 | 08:13 AM
  #16
Bonniewright365's Avatar
wow! i've never seen this before
Old Nov 14, 2011 | 10:49 AM
  #17
Cadsforfun's Avatar
Default Urinals
On that first red tulip model, do you plan on installing it with that french tickler thingy in the center?? I'm thinking the girls will be using that one quite a lot.And not for peeing.
Old Aug 23, 2023 | 04:08 AM
  #18
aspoiwl's Avatar
Insertion Direction: Make sure you are inserting the SD card in the correct direction. The metal contacts on the SD card should be facing down, and the card should slide in smoothly. Do not force the card in the wrong direction, as this can damage both the card and the slot. Check for Dust or Debris: Sometimes, dust or debris can ac***ulate in the SD card slot, preventing proper contact with the card's contacts. Gently blow into the slot or use compressed air to remove any particles that might be causing a connection issue. Verify Card Compatibility: While the SanDisk Extreme Pro 64 GB is a high-quality SD card, it's still a good idea to verify its compatibility with your Surround Vision Recorder. Check the owner's manual or the manufacturer's website to ensure that this specific card model is supported. But wherever you are there is always the possibility of playing at online casinos, by the way, can you tell me how much https://casinosanalyzer.com/online-casinos/taka-bdt can be trusted with this information? Formatting: Ensure that the SD card is properly formatted. If the card was previously used for something else, it might not be formatted correctly for your Surround Vision Recorder. Insert the card into a computer or another device and format it to the appropriate file system (usually FAT32 or exFAT) before trying it in your vehicle again.
Jmoran1
Jul 12, 2023 02:32 PM
Jul 9, 2009 02:17 PM
Nov 7, 2007 04:21 PM
Apr 2, 2007 02:09 PM
Vehicular Projects
Mar 25, 2007 04:50 PM
