won't crank
Old Oct 10, 2007 | 09:46 PM
blackser's Avatar
Default won't crank
I am new to this forum and recently bought a 92 Cadillac Deville. I have an intermittent starting problem. It will sometimes start and then sometimes it won't start(crank over). My security light stays on while cranking and I have tried my spare key. The battery and connections are clean and tight. Sometimes idf I watit about 5-10 mins it will start. Does this sound like a VATS problem? Any help would be appreciated.
Old Oct 10, 2007 | 10:10 PM
Default RE: won't crank
Yes,If keys are in good condition, most likely one of wires from igntion cylinder to base of column is broken. Hope it helps
Old Dec 6, 2008 | 12:54 PM
slsrider13's Avatar
If the security system is the issue will the starter click when you try to turn it over? Thats the issue I am currently dealing with. I have already replaced the starter and it worked for about a week but now when i turn the key the starter just clicks and wont try to turn over. Could that be a security problem?
Old Dec 6, 2008 | 06:26 PM
No, starter will not click.
timmystoys
May 14, 2008 12:48 PM
jaymz8584
Aluminum Block V8s
Nov 1, 2007 06:52 PM
