typical purchase checkpoints for eldorado
Old Oct 16, 2007 | 03:15 AM
Ton's Avatar
Ton
Default typical purchase checkpoints for eldorado
Olla Happy Caddy Drivers,
I'm a dutchy and consideringbuying a Eldorado 1992/1993 (these years, because of fine Dutch tax regulations).
Once bought a Californian Mercedes Bens 450 se. Looked good, but had to rebuild itthe following years.
To prevent buying another corpse, pleasehelp me withsometypical checkpoints for a Eldorado of the mentioned years.
I am familiar with checking normal wear (side noices, ball bearing wear, etc). But what are the favourite weak/rust (considering the Dutch weather) spots of a 1992/1993 Eldorado??
Also would like to knowif Caddilac produced different types of Eldorado's in those years and of course wich isbest tobuy.
Thanx in advance!
Old Oct 17, 2007 | 01:01 AM
Default RE: typical purchase checkpoints for eldorado
ORIGINAL: Ton
Thanx in advance!
- play it safe, have a exhaust gas in coolant test done.
- compression test
- run it at high speed and make sure 4th gear engages and stays engaged w/o dropping down to 3rd for no reason,
- lack of silicones on leathers - they dry and crack
- check for existing codes
- STRUTS ..
- all other standard issues of any car.
as to rust, I cant help you .. our cars don't rust - California.
Old Oct 17, 2007 | 03:46 AM
Ton's Avatar
Ton
Thanx Stealth.
As for the weather, its rainy and foggy as i reply, so on the rust thing i have to trust on my own judgement. Ran into an eldorado yesterday. It seemed that it withstood dutch weather and salt on the road during winter for the last 7 years pretty fine. Wasn't for sale though.
Understood all but the struts. Looked it up, couldn't find it. Do you meanthat the gear change should be smooth??
Old Oct 18, 2007 | 04:00 PM
gopher's Avatar
whats the import regs like there?
Could try to locate one and send it..
Old Oct 18, 2007 | 07:58 PM
Eldos came with one body style. 92s 4.9L only 93 4.9 base ETC 4.6L. 92 could be had with column shift, I not sure you could find one.Back in 1998 I knew of someone who bougtht one, new. He was from scandanavia he got it thru Canada because they would not ship it from US.
Mafijoosi93
Nov 24, 2010 03:50 PM
utahpaul
Jul 9, 2010 09:45 PM
aeliayousaf
Feb 18, 2008 09:37 PM
rwh9056
Jun 4, 2007 07:40 PM
batguano
May 29, 2007 04:48 PM
