twilight sentinel headlights
Old Sep 22, 2009 | 11:16 AM
lildago7741's Avatar
Default twilight sentinel headlights
I have an '81 cadillac deville and
my headlights will not come automatically on at night and I replaced the twilight sentinel amplifier. that did not fix it so I also replaced the eye. still no luck. I discovered when I pull the eye out with the ignition on, they work ok. if I put the eye back in, they will not work. this is why I thought it was the eye.
any help would be appreciated.
thanks.
Jim
Old Sep 22, 2009 | 09:27 PM
New or used parts. Photocell(eye) should have corrected it. You could try to OHM test photocell should have a high resistance value when covered.
Old Sep 23, 2009 | 07:48 AM
the twilight sentinel amplifier was NOS (new old stock) and the photocell eye is new and I tried the OHM test on both photocells and they both go from low resistance uncovered and when covered has a high resistance. it does not appear to be the photocells
thanks for your reply and any other ideas you may have would be welcome
Old Sep 23, 2009 | 08:59 AM
on the connector to the photocell .. what is the voltage across the harness connector when ignition is ON ?
Old Sep 23, 2009 | 10:51 AM
I checked the voltage across the harness connector like you suggested and with the ignition on the headlights come on. I don';t get a voltage reading when I turn the sentinel headlights to off position I get a reading across the harness connection of about eight volts.
thanks again
Extremespeedtrackevents
Aug 7, 2015 01:45 AM
Jul 21, 2015 10:05 PM
Jul 8, 2015 01:46 AM
Deville93
Apr 29, 2011 10:04 AM
liljon
Jan 17, 2005 04:54 PM
