repair front noise question
2003 Deville.
I have front pass. side suspension noise. I have both clunking noises and some rotating noise that I think is starting to get worse.
I believe I put junk product wheel bearings in previously years past.
How would you advise repairing this ?
I thought about buying everything I can to rebuild all. Or just replace the main cause ?
For some reason I can't pin point this damaged part issue in the front.. I keep jacking up car and wrestling wheel and removing wheel and using crow bar to search for bad part, but I can't find anything.
So I guess I need to discover it during tear down.
I was thinking I should replace axle shaft, hub bearing, low ball joint, tie rod end. probably both sides. What would you advise ?
Thanks for helping.
Thanks for helping.
