remove rear rotors?
Old May 13, 2011 | 07:18 PM
lawnsnowguy's Avatar
Default remove rear rotors?
Anyone have any ideas on how I remove the rear rotors from my 2003 cts? The emergency brake is preventing me from pulling them off? Any help would be appreciated.
Old May 14, 2011 | 11:59 AM
gmtechs's Avatar
basically a lot of praying
u need to rock it back and fourth use some type of lub to release the rust in the back.
if u r going to replace the rear rotors use a hammer hit the rotor turn rotor and hit it again continue to do this and it will come off
Old May 14, 2011 | 07:12 PM
Default rear rotors
Do I need to do anything to reset the emergency brake? I have tried several times to pull it off, but was afraid of doing any further damage.
Old May 14, 2011 | 08:30 PM
etbracket's Avatar
There might be a ridge of rust on the outside edge of the rotor where the e brake shoes are located, just keep hitting the the rotor like gmtechs said. Try using a pry bar between the hub and rotor while hitting the back of the rotor. Usually the rotor will come off without any damage to shoes.
lawnsnowguy
May 12, 2011 05:36 PM
lawnsnowguy
May 12, 2011 05:28 PM
Nov 5, 2007 09:57 PM
zdld17
Nov 10, 2005 02:37 PM
Thomas1
Jun 3, 2005 07:35 PM
