Rear right brake light.
How do I change the right rear brake bulb? I went in the trunk, remove the plastic screw nuts but the outside light assembly will not loosen up to be removed so I can change the bulb. What am I missing?
Thanks!
Thanks!
having just changed mine... i took and tapped the threaded stems the plastic wing nuts came off of.... lighty! if i remember correctly, i had to pull out the trunk felt to get all the plastic wing nuts........ hope it helps
99STSGUY
Jan 21, 2009 08:29 AM
jono6406
Feb 13, 2008 12:13 PM
