Radio issue?!
Old Mar 12, 2011 | 04:17 PM
ClassicCollect's Avatar
Default Radio issue?!
Here's the story:
So the radio went out one day and I changed the fuse and it was fixed, no big deal right? Well, 6 months later it went out again after I pressed the "Loud" button on my control panel. I changed the fuses again, however this time the problem did not fix itself?! The clock still works so I know the fuse/power is working, however the antenna does not go up, and the radio will no longer turn on when I hit "power". Is the radio just toast? Or is there a quick fix to this problem I'm not thinking of?! ANY help would be much appreciated! Thanks in advance to all those who have advice or similar problems willing to discuss.
Old Mar 13, 2011 | 01:22 AM
Cadsforfun's Avatar
Default Radio
I'm assuming this is a Cad you are talking about, as you don't specify.Is the antennae fuse ok?? Are the front park and marker lites working?? Improper speaker hookup could cause a problem.How about the lighter fuse. Check all grounds and also the pink wire to the power antennae relay.Good luck. Electrical gremlins are fun aren't they???
Old Mar 13, 2011 | 05:46 AM
92_Daddylac's Avatar
need more info. year and model and if it is a BOSE or not.
theatreman
Mar 26, 2009 05:30 AM
Jroc
Oct 1, 2007 11:39 PM
realmofdefiance
Oct 17, 2006 12:22 AM
jimbo49
Aug 4, 2006 11:31 PM
Freethinker
Jul 10, 2006 11:40 PM
