Procedure for Replacing Half-Axle
Old Aug 24, 2017 | 11:52 PM
Drbrown's Avatar
Default Procedure for Replacing Half-Axle
Have a Factory Manual, a 1984 Eldo 4.1 auto FWD, and a RH half axle with broken outer rubber boot. As I read it, Manual says I must disassemble the ball joint and install temp boot straps in order to drop the RH axle. Do you really have to do this ??
I ask because I've done half axles on other cars, and usually the RH unit was more difficult. Factory Manuals often said front end parts must be disassembled but it turned-out it was just a matter of turning the wheel in a certain direction and juggling the axle unit in a certain way.
Old Sep 5, 2017 | 12:08 AM
Drbrown's Avatar
Guess I (and receipt of my new FM) answered my own question. After studying the right front wheel assembly I see all the drive and suspension components crammed into that small space. As well, grinding off the rivets to remove the ball joint sounds challenging. Think I'll bite the bullet and have someone do the job.
RacingJunk
Aug 17, 2017 03:34 AM
Bountyhunter
Feb 29, 2016 01:48 PM
goodfella
Apr 8, 2009 09:42 PM
brisul
Jun 27, 2007 08:18 PM
Torrence
Jul 26, 2006 07:28 AM
