Problems 90 Sedan DeVille
Old Mar 29, 2010 | 05:28 AM
BossHogg281's Avatar
Default Problems 90 Sedan DeVille
My Cadillac starts up perfectly every time. No noises or anything. It idles just fine but when i put it in drive and i hit the gas, it hesitates and the engine just cuts off. I have a new battery, alternator, hoses, and even had a tune up not too long ago. Any suggestions or help would be greatly appreciated.
Old Mar 29, 2010 | 06:29 AM
fuel pump????? did this just start all the sudden???
Old Mar 29, 2010 | 06:35 AM
yea i had been driving it and this problem just started... and my fuel pump is pretty much like new
Old Mar 29, 2010 | 07:21 AM
Adams' Apple's Avatar
Sounds like a TPS(throttle position sensor) issue. Try unplugging the TPS and see what it does. It won't run very well like that, but if the TPS is the problem, it will run differently.
Could also be a fuel pressure issue, so you would need to verify the fuel pressure to see.
An ignition module going out could also cause this, but they usually fail mostly when hot.
Have you tried to get any codes from the system, and if so, what are they?
Old Mar 29, 2010 | 08:35 AM
I honestly dont know where the TPS is. I cant find my book. And no i havent taken it anywhere so i have no codes
Old Mar 29, 2010 | 09:12 PM
TPS bolts on side of throttle body, it has 3 wire connector.
Old Mar 29, 2010 | 09:54 PM
Sorry...I sometimes forget that people don't always know what the heck I'm talkin about.
The TPS is indeed screwed on to the side of the throttle body, which is where the carburetor would be if it wasn't fuel injected. If you remove the air cleaner housing from the center of the engine, the throttle linkage will be towards the radiator side of the throttle body. Then look on the opposite side of the throttle body, directly across from the linkage, and you'll see a small black part screwed to the body, with a 3 wire electrical connector on it. That is the TPS.
Old Apr 2, 2010 | 09:40 AM
joshtimber81's Avatar
Same way is used in every make and model or it is just for specific one.
Old Apr 5, 2010 | 04:08 PM
victorminisan's Avatar
check your fuel filter also
ljpp33
Mar 24, 2009 12:33 AM
duajones
Jan 23, 2009 06:45 PM
Jgauthier
Sep 21, 2008 08:02 PM
WILDCARDRACER1@YAHOO
Aug 22, 2007 02:32 PM
SIRS
Jun 3, 2007 06:21 PM
