Problem with car, Duh
Old Nov 14, 2007 | 02:12 PM
hearsedriver's Avatar
Default Problem with car, Duh
MOVED YOUR POST TO GENERAL TECH SO YOU MIGHT GET AN ANSWER FASTER.
I own a 69 Hearse. It is dismantled for resto. 472 engine. This is a long story with multiple problems.
Fired her up and had to stay on the gas to keep her runnin. Stalled. Would not even start again. Turn key and get nothin,no click , no starter movement, gen light on. Batery ok! Alt ok! Cleaned battery cables,(battery ends, and solenoid end, and grounds. Cleaned solenoid lug and the other two conectors attached to wires down on the lug. Put it all back together. Put key in ignition, gen light on before i turned key! Turn key and get nothing,like before. Gen light stays on no matter if key in or not. What did i mess up now? If i "short" the solenoid to the starter it turns but does not engage the engine. I know the engine has a tuning or choke problem,not woried about that now,want to get the starting system right first. Help isappreciated in advance. PS i am not an ENGINE guy so keep it simple. Thanks.
Remember, any day above ground is a good day!
Old Nov 15, 2007 | 12:02 AM
Default RE: Problem with car, Duh
jeezzzz .. what happened?
it seems you may have several issues.
starter - pull it off and run it on the bench, on battery. IF the gear doesnt extend, you need a new one.
timing - it may be off,
timing 2 - firing order,
timing - timing chain or distributor,
firing - plugs, gaps, fouled, cracked, etc
wiring - something seems mis-wired here, hope you got pictures or wiring diag.
Old Nov 15, 2007 | 08:42 AM
gmwarranty's Avatar
Welcome to the Cadillac Forum!!
_____________________________
Cadillac Extended Warranty - Are you covered?
Are your other GM vehicles covered with a General Motors Protection Plan (GMPP)?
Old Nov 15, 2007 | 04:27 PM
Thanks guess ill start with the starter
Old Nov 25, 2007 | 01:49 AM
1999frc's Avatar
if the starter is slow than that is a problem. try oiling the gear shaft. caddys have an issue with timing chain stretch, but i would almost guess that you have carb problems, dan
JBeam4ME
Jun 17, 2023 04:07 AM
davidreiff
Aug 26, 2014 06:54 AM
Lac Lover
Sep 10, 2012 09:53 AM
merry
Aug 27, 2008 03:05 AM
