P0106 and P0122
Old Jul 14, 2011 | 06:08 PM
toolmaker's Avatar
Default P0106 and P0122
I still have my 2001 Eldo. Hopefully not much longer. I have had dealer replace intake plenum, both front wheel bearings, dual zone climate "valve?", water pump & crossover, then intake plenum o-ring(apparently good when first repaired?)tie rod end they left loose, ALL fluids/filters replaced...
Anyway, I`ve had electrical glitches since owning car. Radio not working once, driver window, no ignition, then all DIC info resetted itself to zero.
Now I have "check engine" on, P0122, and P0106 current.
Car will not drop into lower gear with pedal to floor, and idle is all over the place at times.
I`ve read maybe TPI, MAP, MAS sensors or shorts in circuits.
Oh yeah, my fuel gage hasn`t worked for a year, so I`ve been using my gallons of fuel used. But now that reset itself when DIC reset.
I used to love my caddys`, but this one has been a miserable headache.
Any ideas would be appreciated. (Before I go drop another grand to get some new problem)
Thanks,
Mick
Old Jul 20, 2011 | 07:12 AM
jono6406's Avatar
Trade it in and drop that grand into a newer Caddy
Stephen Kirby
Apr 28, 2014 11:56 PM
Sep 25, 2009 01:16 AM
