OBD Port
Old Jun 13, 2017 | 04:34 PM
louis7808's Avatar
Question OBD Port
2000 Seville Where is the diagnostic port located? I looked under the drivers side dash and could not find it. Is it behind a panel? Please help.
louis7808
Old Jun 14, 2017 | 04:12 PM
Under drivers side hush panel
Old Jun 14, 2017 | 04:38 PM
louis7808's Avatar
Thank you, found it. Next problem is power windows, only the drivers window operates none of the others will work. The door locks have the same problem, only the drivers door works. I checked for blown fuses but found none, are they controled by relays,or modules?
Still confused
louis7808
Old Jun 14, 2017 | 06:57 PM
Window lock on? Modules control most things. tech2 recommended for diagnosis, you will need at least a wiring diagram. You really will need a FSM on disc. GM went away from paper manuals in 2000
tallis51
Dec 15, 2012 09:13 AM
willfeom
Jan 17, 2011 05:43 PM
cadillacsmith
Jul 9, 2009 12:05 PM
cadillacsmith
Jul 9, 2009 11:53 AM
jaycough
Oct 14, 2006 11:38 AM
