No Start
Old Aug 12, 2012 | 01:10 AM
adixon3's Avatar
Default No Start
I have 1994 Seville SLS and the problem is the car was idling really high because of a few missing vacuum lines and then after a while it would crank but not start at all so I replaced the vacuum lines thinking that would fix the problem but it still won't start I put more gas in the tank still nothing so next I thought maybe the fuel pump is bad I checked the fuse, hooked up a pressure gage to the fuel rail test fitting and jumpered the fuel pump relay did not hear the pump start nor get any fuel pressure so i'm thinking it's the fuel pump i'll hate to replace the pump and have that not be the problem also. Is there anything else that could cause this. Here's my error codes p052, p061, p062, p065, p109, I052, r061, r062, S036, s061, s070, s071
Old Aug 18, 2012 | 08:57 PM
rider's Avatar
That same thing happen with my deviile and it was the hoses of the fuel pump
wekinla
Jan 17, 2009 11:26 AM
