no power to a/c pump
Old May 27, 2010 | 11:45 AM
mycam8u2's Avatar
Default no power to a/c pump
i have a 91 deville. there is no power going to the plug for the pump. i checked the fuse under the hood and that is good.i dont know what else to check.
Old May 28, 2010 | 08:01 PM
BCM can disable a/c. Check for codes and clear or disconnect battery for 10 sec., then re-connect and see if compressor will engage. Low freon will set code and disable compressor/pump. Compressor relays did tend to fail during the early 90's.
Old May 31, 2010 | 09:08 PM
mycam8u2's Avatar
problem solved..thanx
89whitefleet
Sep 25, 2008 02:11 PM
kmec
Feb 11, 2008 09:32 AM
jxer00
Oct 3, 2007 05:08 PM
tspope99
Aug 1, 2007 04:20 PM
srchapman
Mar 31, 2007 12:02 AM
