need help please gauge cluster
Old Jan 7, 2008 | 08:58 AM
shag596's Avatar
Default need help please gauge cluster
i have a 1994 seville sls and the gauge cluster dosent work. i sure its a ground but unsure of which one. when you turn the car on the defroster starts blowing and you cant turn it off because none of the buttons work. any help would be appreciated. thanks
Old Jan 7, 2008 | 06:11 PM
Default RE: need help please gauge cluster
Check for codes then post. What gauge(s) doesn't work?
Old Jan 7, 2008 | 07:35 PM
shag596's Avatar
i cannot check for codes because the a/c screen and the screen that shows the fuel milage dosent work, and the buttons dont do any thing when you press them. i know the parking brake light, abs, seat belt, anti lock,and air bag light come on but nothing else does. even the service engine soon light doesnt come on
Old Jan 7, 2008 | 10:57 PM
Did this condition come about, after engine repair in othe post?
Old Jan 8, 2008 | 08:01 AM
shag596's Avatar
no this conditon already existed. is there any other way to check codes with out using a scanner or the on board diagnostics?
Old Jan 8, 2008 | 08:12 AM
ORIGINAL: shag596
please read this thread and go by it so we can help.
Old Jan 8, 2008 | 08:47 PM
Need as much back ground about car as you can provide. You also need factory service manuals. Why was engine changed and did you take it out the top or drop it out the bottom?
Old Jan 8, 2008 | 09:48 PM
shag596's Avatar
i took the motor out to fix what i thought was a rod knock but it ended up being a timing chain tensoner. i pulled the motor out from the bottom. i dont know to much about the back ground on the car because i bought it to fix it for my wife. when i bought it i drove it home the gauge cluster didnt work and there was a tapping coming from the motor i can not tell you the actual milage on the car. i have been working on the car for about 6 months. i would work on it a little bit here and there. the motor has been out of the car from about june last year until december of last year. (2007 )... in december i finally put the motor back in the car andthats where im at now. i have every thing that i can find hooked up and to there properlocations. i dont know if not having a battery in the car for 6 months cleared any thing in the computer or if there is something else wrong. where would i get factory servicemanuals?
bobbyking1988
Mar 14, 2013 12:30 PM
Sam_Ryan
Oct 15, 2009 08:44 PM
NOGUTSNOGLORY
Nov 16, 2008 08:15 PM
tidewins
Jul 17, 2007 12:06 AM
2000Falcon
Mar 28, 2007 10:22 AM
