Need help
Old Feb 16, 2010 | 06:28 PM
koolbrezz's Avatar
Default Need help
i have a 1999 cadillac deville service ride system is comeing on i have the bad codes here they are............ pcm po603 history........ipc b1552 history.......rss c1762 current.........pzm b1552 history any help would be great thanks...........
Old Feb 17, 2010 | 12:19 PM
Adams' Apple's Avatar
P0603= VCM memory reset(could be set by disconnecting the battery)
C1762= Left rear position sensor input fault
B1552= Loss of BCM keep alive memory(could also be set by disconnecting the battery)
As far as the C1762, first check to see the the connector for the LR sensor is plugged in correctly, and is not corroded. From there, the service manual can help with the diagnostics, if you have it. If not, then first check the connector, and post back. The sensors seem to have a problem with the connectors, as well as water intrusion.
hth
Gregg Reed
Apr 13, 2014 09:09 PM
cadillactt
Mar 12, 2008 01:31 AM
kmac171
Feb 20, 2008 10:36 PM
nizmosis
Sep 30, 2005 06:20 PM
redbirdT/Aws6
Dec 22, 2004 01:31 PM
