low pitched groan
Old Nov 14, 2009 | 03:00 PM
  #11
Rzr's Avatar
Rzr
I can say its not the tires as the tires only have about 2k miles on them... all of it highway.
like i said before sound come from right front wheel, and goes away from turning right so i think your analysis slowroll hits it right on the head. gonna see if i can look at it tomorrow and will let you know.
on a side note anyone know what that gear thing is?
"When doing the brake job i noticed behind the roter and all on the drive shaft by the hub there was a gog shapped ring around the shaft... i have no idea what it is used for (my best guess would be a speed sensor or something to that nature) but i noticed that there was a ware ring on the cog in the center from what i assumed was a bolt of some sort that came out of the hub assembly (i believe.... cant quite remember) i looked at this bolt looking dodad and could not figure what it was or anything or if it had to do with the groan."
Old Nov 19, 2009 | 03:29 PM
  #12
Rzr's Avatar
Rzr
so update, took the wheel assembly apart the other day and it was a bad bearing on the front left axle... problem solved now... thanks all.
Tanzanite3
Mar 2, 2006 11:32 PM
SuMeRbOaRd
Mar 1, 2006 02:54 PM
JoeBlowRacing
Oct 10, 2005 04:37 AM
old_school_fleetwood
Apr 20, 2005 01:59 PM
sandawgcaddy
Dec 2, 2004 08:39 PM
