95 Won't stay running at low RPM/IDLE
Old Aug 28, 2005 | 07:28 PM
SuMeRbOaRd's Avatar
Default 95 Won't stay running at low RPM/IDLE
Hey, my 1995 won't stay running sometimes when it is idleing. Sometimes it runs fine, others it dies right away. Would pulling the battery wire off for a little while and hooking it back up allow it to relearn everything or does it constantly adjust? Like.... does the computer stay set once it learns everything after you hook the battery, or does it always adjust even after the batterys been hooked up for months.
Old Mar 1, 2006 | 02:54 PM
_X_CaddyTech's Avatar
Default RE: 95 Won't stay running at low RPM/IDLE
check ISC motor for proper operation....there is a learn procedure for this..unhooking the battery will solve nothing...also could be a faulty ECM
Richygot1
Sep 12, 2009 01:37 AM
triker3w
Apr 14, 2009 08:58 PM
yahripley
Mar 28, 2009 09:23 AM
jhnnburns
Dec 30, 2007 10:34 AM
micromachine07
Feb 28, 2005 01:31 PM
