Just Purchased STS 1992
Old Nov 4, 2007 | 11:20 AM
Nah wutt's Avatar
Default Just Purchased STS 1992
Hello I have a 1992 Seville S.T.S. and it rides kind of hard I have to repair the oil pan gasket (was told) its a leak, and had to flush radiator badly, the in dash lights only come on when they want to i cant read the inside car temp do to the fact it doesnt light up and I need to replace the Drivers side mirror and the seat its ragged out and doesnt move. The error codes are as followedIPC) I022 , I033, I034, I037 , I039 ,(SIR)R026 ,R061 ,(ACP)A048 I replaced the struts but the message keeps saying suspension issues, I also repalced the rear brake pads and rotars but the messages that come up everytime I get inside is 'Oil needs changing, suspension issues and very low refrigerant', also when it runs it seems to idle high when i first start to drive it and the electric seems to be iffy I changed fuses in the trunk( new)the front lighters dont work and there is no power to the front driver's seat. thanx any and all help is welcome .
Old Nov 4, 2007 | 01:49 PM
Default RE: Just Purchased STS 1992
Car has oil life system, you will need to reset it when oil is changed. If car has regular struts on it. service sss light can be turned off . You can see dealer to bypass module and turn off light.You need to get factory service manual, even it you can find a tech. Cat jumped on key board. Excuse the code
Moderator edit:
I thought I was the only one with a smart typing cat.
couldnt read as-is, fixed screen codea
Old Nov 4, 2007 | 07:33 PM
G.A.R.Y.'s Avatar
owners manual here with tape.
http://www.prodfinds.com/products.as...d=170163573557
Probably find on e-bay cheaper also find on e-bay service manuals.
Old Nov 5, 2007 | 03:17 PM
autorepairinfo.org i got a cd rom through these guys for my 99sts..... 20.00 check it out.....
welcome to the forum dude....good luck with your sts.
Old Nov 6, 2007 | 06:53 AM
Nah wutt's Avatar
Thanx Fellas For Your Help Very Much Appreciated!!!!
gmanney
Aug 24, 2009 01:58 PM
ZBrink
Sep 19, 2006 01:12 AM
jchutch
Jul 17, 2006 11:37 AM
danksontl
Jun 11, 2005 09:52 PM
